Fixtures missing?
15 Nov 2016 03:24 #82827 by jeeybee
Fixtures missing? was created by jeeybee
Hello!
All my fixtures G55- has dissapered, all seem to be zero :( how can this happen?
Also where are these stored?
15 Nov 2016 07:13 #82832 by Todd Zuercher
Replied by Todd Zuercher on topic Fixtures missing?
They are saved in a file in your configurations dir ending with .var. Is there a chance you may have deleted it? There may be a backup file in your dir ending with .var.bak.
15 Nov 2016 09:02 - 15 Nov 2016 09:03 #82833 by Todd Zuercher
Another posibility is that in your ini file under the [RS274NGC] section there is a setting that defines what the name of the .var file and it's location.
linuxcnc.org/docs/2.7/html/config/ini-co...ml#_rs274ngc_section
Last edit: 15 Nov 2016 09:03 by Todd Zuercher.
18 Nov 2016 04:12 #82953 by jeeybee
Replied by jeeybee on topic Fixtures missing?
The INI file is correct and the var file is still there, although all numbers are zero, very strange.
18 Nov 2016 07:21 - 18 Nov 2016 07:29 #82959 by eFalegname
Replied by eFalegname on topic Fixtures missing?
Hi, after a crash the linuxvar file is emptied and the parameters of fixtures get lost, try to restore the backup copy of the file linuxvar file it's possible you can have them from it again.
Last edit: 18 Nov 2016 07:29 by eFalegname.
21 Nov 2016 11:27 #83084 by jeeybee
Ok... does that include if the power goes out or if the computer power is turned of without closing linuxcnc first?
21 Nov 2016 12:02 #83087 by Todd Zuercher
I don't think I've every had it happen to me.
21 Nov 2016 12:30 - 21 Nov 2016 12:35 #83089 by eFalegname
Yes mate, an abnormal termination of the program always involves the loss of some data. I live in an area where there are frequent surges of power that is why I connected my LinuxCNC PC to an UPS.
Last edit: 21 Nov 2016 12:35 by eFalegname.
Time to create page: 0.291 seconds
