Fixtures missing?
- jeeybee
9 years 11 months ago #82827
by jeeybee
Fixtures missing? was created by jeeybee
Hello!
All my fixtures G55- has dissapered, all seem to be zero
how can this happen?
Also where are these stored?
- Thank you received: 1480
9 years 11 months ago #82832
Replied by Todd Zuercher on topic Fixtures missing?
They are saved in a file in your configurations dir ending with .var. Is there a chance you may have deleted it? There may be a backup file in your dir ending with .var.bak.
9 years 11 months ago - 9 years 11 months ago #82833
Another posibility is that in your ini file under the [RS274NGC] section there is a setting that defines what the name of the .var file and it's location.
linuxcnc.org/docs/2.7/html/config/ini-co...ml#_rs274ngc_section
Last edit: 9 years 11 months ago by Todd Zuercher.
- jeeybee
9 years 11 months ago #82953
by jeeybee
Replied by jeeybee on topic Fixtures missing?
The INI file is correct and the var file is still there, although all numbers are zero, very strange.
- eFalegname
- Thank you received: 30
9 years 11 months ago - 9 years 11 months ago #82959
by eFalegname
Replied by eFalegname on topic Fixtures missing?
Hi, after a crash the linuxvar file is emptied and the parameters of fixtures get lost, try to restore the backup copy of the file linuxvar file it's possible you can have them from it again.
Last edit: 9 years 11 months ago by eFalegname.
- jeeybee
9 years 11 months ago #83084
by jeeybee
Ok... does that include if the power goes out or if the computer power is turned of without closing linuxcnc first?
Time to create page: 0.198 seconds
