lead screw accuracy compensation
- yvon caron
17 Nov 2016 05:20 #82881
by yvon caron
lead screw accuracy compensation was created by yvon caron
how to compensate the accuracy of my 16"x travel lead screw?
thankls
thankls
- Thank you received: 4652
17 Nov 2016 10:32 #82885
Replied by andypugh on topic lead screw accuracy compensation
If you have a way to accurately measure the true position then you can use a screw compensation file:
See the COMP_FILE and COMP_FILE_TYPE settings here:
linuxcnc.org/docs/2.7/html/config/ini-co...s__lt_num_gt_section
Time to create page: 0.069 seconds
