Spindle accelerates too fast
- an92626
19 Nov 2016 19:26 #83001
by an92626
Spindle accelerates too fast was created by an92626
My spindle errors out when I try to directly set the speed too high.
My spindle motor is capable of spindle speeds up to 6000 rpm. I can reach the 6000 rpm level if I slowly step up the spindle speed; such as manually increasing the spindle speed by 100 rpm increments up to 6000 rpm; but if I issue a M5 S5000 or greater, the spindle controller issues an overload condition and the mill shuts down. I can issue a M5 S4000 with no problem.
I am assuming that the overload condition occurs because I am trying to force the spindle to the higher speed at too high of a rate. (i.e. the acceleration level is too high.)
The spindle section of my ini file is as follows:
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 6000.0
OUTPUT_SCALE = 6150
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 6000
note: The slight change in the OUTPUT_SCALE value to 6150 is there to adjust the spindle speed to its true measured spin rate.
Is there a way to slow the rate that Linuxcnc changes the spindle speed? I really have no need for instantaneous changing of the spindle speed.
Thanks.
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 6000.0
OUTPUT_SCALE = 6150
Thanks.
- Thank you received: 5321
19 Nov 2016 20:01 - 19 Nov 2016 20:07 #83004
Replied by PCW on topic Spindle accelerates too fast
If this is a VFD controlled spindle you should be able to do this by proper VFD setup
You can also do this in LinuxCNC by using the limit2 component to limit the acceleration:
linuxcnc.org/docs/html/examples/spindle....#_spindle_soft_start
Last edit: 19 Nov 2016 20:07 by PCW.
- Thank you received: 1472
20 Nov 2016 01:22 #83013
Replied by Todd Zuercher on topic Spindle accelerates too fast
Yes properly configuring your VFD for your motor can make a huge difference, in how they perform. I bought a new machine that did not have the VFDs properly configured for the spindles, and getting them set right made a huge difference. Noticable increases in torque at high speeds and much more. Do carifully read your manual for the VFD and set all its parameters to what they need to be for your setup.
Time to create page: 0.496 seconds
