Help needed to setup auto tool offsets
19 Nov 2016 23:54 #83012 by suspension
Help needed to setup auto tool offsets was created by suspension
Today I migrated from planencnc USB to LinuxCNC and things have been good so far. However I am having some difficulty setting up automatic tool offset detection. Since I am new to gcode I cant figure out what the problem is exactly.
I have tried executing following code to determine Z offset of the current tool.
option1
G90
G38.2 Z-10 F50
G0 Z2 F50
G92 Z27
Above one fails always saying Z-10 is not with in the limits. (However my Z axis negative limit is around -60). To fix that, I changed G90 to G91 and this error went away. However after executing the full command set, G92: Z value does not show 27 as expected.
Then I tried option 2 below again with similar results:
G91
G38.2 Z-10 F50
G10 L2 P0 Z25
G0 Z2
I expect G92:Z value to be 27, but it shows something else.
Could any one let me know what I am doing wrong here?
Also, the the button 'Tool touch Off' in axis GUI is disabled. What could be the reason for that?
20 Nov 2016 10:35 #83027 by andypugh
Replied by andypugh on topic Help needed to setup auto tool offsets
G92 Z27
I don't think G92 is the right thing to use here.
G10 L2 P0 Z25
G0 Z2
G10 is the right thing to use. That sets the tool offset or the work-coordinate offset.
G10 will not change the G92 value. I would suggest, for simplicity, running G92.1 in the MDI to clear the G92 offsets.
It is probably greyed-out because you don't have a tool loaded (or, to be more precise, LinuxCNC doesn't think you have a tool loaded). MDI M6 T1 G43 to make LinuxCNC aware that tool 1 has been loaded.
I suspect that your code might want to use G10 L20 or maybe G10 L11.
linuxcnc.org/docs/2.6/html/gcode/gcode.html#sec:G10-L2_
20 Nov 2016 13:07 - 22 Nov 2016 08:20 #83037 by eFalegname
Replied by eFalegname on topic Help needed to setup auto tool offsets
Hi suspension, there is a fine configuration example for the manual toolchange with auto z and tool lenght touch off here:
Manual tool change
pyvcp example
Last edit: 22 Nov 2016 08:20 by eFalegname.
20 Nov 2016 16:59 #83041 by suspension
Replied by suspension on topic Help needed to setup auto tool offsets
Thank you all.
The coordinates shown in Axis display was bit confusing so I switched to gmoccapy.
Also I changed the line G10 L2 P0 Z25 to G10 L20 P0 Z25 and it works fine now.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
20 Nov 2016 21:34 - 20 Nov 2016 21:37 #83046 by Todd Zuercher
Replied by Todd Zuercher on topic Help needed to setup auto tool offsets
Tool touch off is disabled until you tell Linuxcnc to load a tool (T1 M6).
www.linuxcnc.org/docs/2.7/html/gcode/tool-compensation.html
As to your soft limit problems, I;m not sure where to start. Does your machine use home or limit switches? How do you have your homing configured? Is Z0 at the top of the Z travel?
(Edit)
Sorry, Not sure why I didn't see all the replies to the original message before I typed and sent this.
Last edit: 20 Nov 2016 21:37 by Todd Zuercher.
Time to create page: 0.274 seconds
