X11 forwarding to macOS Sierra
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Nov 2016 08:26 #83024 by phillc54
X11 forwarding to macOS Sierra was created by phillc54
Is anyone successfully using X11 forwarding to macOS Sierra with Axis as the UI?
I have it kinda working but if I switch tab pages to the DRO or any gladevcp panel then the tab display changes to a black background with no foreground.
When Linuxcnc first runs I get the following:
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Cheers, Phill
20 Nov 2016 12:31 #83033 by andypugh
Replied by andypugh on topic X11 forwarding to macOS Sierra
I can't recall if Axis works for me, but other things do.
Are you using ssh -Y ?
  • phillc54
  • Platinum Member
  • Platinum Member
21 Nov 2016 00:25 #83049 by phillc54
Replied by phillc54 on topic X11 forwarding to macOS Sierra
Yes, I am using ssh -Y
I am running LinuxCNC 2.8.0-pre1-2758-g1bcd51e on jessie 64bit with 4.4.0-trunk-rt-amd64 kernel
Using the stock sims, touchy and tkemc appear ok
axis behaves as above
gmoccapy has a blank white preview screen and if any window appears above it then remnants of that window stay in the preview area
I cannot seem to find any error messages.
All the above work fine on the linux machine.
  • phillc54
  • Platinum Member
  • Platinum Member
21 Nov 2016 07:07 #83054 by phillc54
Actually that is not quite right...
Gremlinview doesn't work in touchy, all that appears are the controls on the left side.
22 Nov 2016 17:37 #83137 by andypugh
I just tested. With my Mac running Sierra and XQuartz 2.7.9 (xorg-server 1.17.4) I can run Touchy and Mini but Axis and Gmoccapy don't even start, failing with various GLX errors.
So, I think you are actually in a better position than me.
logging in via ssh to the same machine from a VMWare Fusion LinuxCNC installation works OK though.
  • phillc54
  • Platinum Member
  • Platinum Member
22 Nov 2016 22:42 #83148 by phillc54
I tried XQuartz 2.7.7 thru 2.7.11 without success and also tried macports xorg-server 1.18.4
Thanks for the virtual machine tip, I tried a Linux appliance in VirtualBox and it works OK as well.
The reason I am trying this is I want to run my LCNC machines headless and I want to have one workhorse machine in my workshop to connect to these plus be my everyday computer. I am also using Fusion 360 and really did not want my workhorse to be a windows box. It seems you have saved me from going down that path.
  • phillc54
  • Platinum Member
  • Platinum Member
11 Jan 2017 05:36 #85604 by phillc54
I have settled on XQuartz 2.7.7 with x2go which allows a single application session.
All later versions of XQuartz (up to 2.7.11) don't seem to work correctly.
I did try VMware Fusion and VirtualBox but Gremlin updates were very ordinary on both (very laggy).
11 Jan 2017 22:29 #85630 by andypugh
I use the latest version and it seems to work fine.
Do you use ssh -Y ?
The -Y switch seems to be necessary.
  • phillc54
  • Platinum Member
  • Platinum Member
11 Jan 2017 22:45 #85632 by phillc54
When using basic X forwarding I do use ssh -Y, the problem I have is that when I switch tabs parts of the preview (gremlin?) remain where they were. If I use x2go this problem resolves itself...
Later versions of XQuartz with x2go cause problems when exiting.
Time to create page: 0.133 seconds
