Gpio outputs
07 Dec 2016 03:34 #83725 by johnmc
Gpio outputs was created by johnmc
Good Day all,
I am trying to set up my classic ladder file and wish to turn some outputs on and off for testing.
Is it possible, to force an output on if it is in the hal file?
Or must it be taken from the hal file, and use a M code greater than M100, then operate output through MDI.
Regards john
07 Dec 2016 05:30 #83727 by Rick G
Replied by Rick G on topic Gpio outputs
If it is not connected to a signal you can use setp.
linuxcnc.org/docs/2.5/html/hal/basic_hal...setp_a_id_sub_setp_a
For testing you can enter it from the hal configuration window.
linuxcnc.org/docs/2.5/html/hal/basic_hal.html
Rick G
The following user(s) said Thank You: johnmc
