Error,
9 years 10 months ago #84180 by tommylight
9 years 10 months ago #84185 by tjamscad
I did, I don't see any debug information.
9 years 10 months ago #84188 by tommylight
Ok, does linuxcnc start? Does the machine move. Anything?
9 years 10 months ago #84191 by tjamscad
tommylight wrote: Ok, does linuxcnc start? Does the machine move. Anything?
Linux CNC loads, estop reset and machine on. As soon as it loads it gives the real time error. I can turn it on and home all it moves fast and gives a following error.
9 years 10 months ago #84196 by tommylight
Ok that is nice progress, now you are getting real time errors so you have to use a larger base thread in the ini file.
Start linuxcnc and move all the axis by hand one by one while checking the dro on screen, the values should change with movement. If it does, check the acceleration and velocity values, and check if you are using inch or metric .
9 years 10 months ago #84288 by tjamscad
I have was put under the impression that the PPMC stuff doesn't use the base thread. It is commented out in my machine.
Time to create page: 0.153 seconds
