mpm@enshu:~$ sudo /usr/bin/linuxcnc '/home/mpm/linuxcnc/configs/new_ppmc/enshu_touchy/enshu.ini'
[sudo] password for mpm:
LINUXCNC - 2.5.4
Machine configuration directory is '/home/mpm/linuxcnc/configs/new_ppmc/enshu_touchy'
Machine configuration file is 'enshu.ini'
Starting LinuxCNC...
enshu.hal:868: Pin 'ppmc.0.encoder.04.position' does not exist
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/mpm/linuxcnc_debug.txt
and
/home/mpm/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
mpm@enshu:~$
