Error,
9 years 10 months ago #84062 by tjamscad
Replied by tjamscad on topic Error,
Ok, I will but I just replaced the whole computer with my spare computer and harddrive with backup from six months ago. I am still getting errors.
9 years 10 months ago #84063 by cncnoob1979
Replied by cncnoob1979 on topic Error,
Post your entire configuration directory as an attachment here on the forum.
Type:
Sudo dmesg -c
prior to running linuxcnc and copying your error file from dmesg -c.
It clears your dmesg log so we can just see the errors related to linuxcnc.
Also post your dmesg.
Linuxcnc error log as well too please. We can get this going for you again or at least point to your problem.
Are you in the USA? If so contact me via email in my profile and we can chat on the phone when we get time.
9 years 10 months ago #84064 by tjamscad
Ok, I will try that. I have now swapped the computer, hardrive and memory.
9 years 10 months ago #84066 by tjamscad
Here is what I get from dmesg. I will have to provide a drive link for the config directory. drive.google.com/open?id=0B86EwtSOzbrjVENZMkdNMlJvZWc
9 years 10 months ago #84067 by PCW
Replied by PCW on topic Error,
[ 203.249005] PPMC: ERROR: no boards found on bus 0, port 0378
This is a completely different error (and not unexpected with a new PC)
Is the new PCs parallel port located at 0x378 and set into EPP mode?
(these would be BIOS settings)
9 years 10 months ago - 9 years 10 months ago #84090 by tjamscad
Yes those settings are correct.
Last edit: 9 years 10 months ago by tjamscad.
Time to create page: 0.292 seconds
