Error,
9 years 10 months ago #84046 by tjamscad
Replied by tjamscad on topic Error,
Bad news it's back, not running
9 years 10 months ago #84047 by PCW
Replied by PCW on topic Error,
Same dmesg error?
sounds a bit like failing hardware
9 years 10 months ago #84052 by tjamscad
Yes saying error I am running memtest
9 years 10 months ago - 9 years 10 months ago #84053 by cncnoob1979
Replied by cncnoob1979 on topic Error,
I would clone the hard disk or replace the hard disk with a backup immediately. Looks like the disk is about to fail, or it too late and has failed already.
EXT4-fs (sda2): warning: maximal mount count reached, running e2fsck
this has been flagged on the Linux file system. Sometimes typical power failures ect.. causes corruption and can be tagged as needing to be checked with e2fsck. But in your case a steady build that is acting "strange" indicates a failing disk. Or corrupt data is being written for other reasons, faulty hardware ; memory ; drive controller.
EDIT: have you ran e2fsck to check the file system?
sudo tune2fs -c 0 /dev/sda2
e2fsck -v /dev/sda2
Link here
This should reset the mount count warning. The issue is perhaps you have corrupted data, either from faulty drive or from multiple powerfailures ect without running e2fsck afterwards. (not shutting down completely prior to power off)
my .02 ;)
Realtime system did not load
Have you tried to reload linuxcnc after you get his error? Sometimes when I get this error a reload will bring it back up.
Last edit: 9 years 10 months ago by cncnoob1979.
9 years 10 months ago #84058 by tjamscad
When typing this e2fsck -v /dev/sda2 I get error message you must have r/w access to the file system or be root
9 years 10 months ago #84061 by cncnoob1979
Use the command:
sudo
Prior to that command. Sorry forgot to put that in there.
The following user(s) said Thank You: tjamscad
Time to create page: 0.340 seconds
