Return to Home Command
08 Dec 2016 16:30 #83782 by Mike29
Return to Home Command was created by Mike29
Hi, I'm using the Axis Gui and the quick reference indicates that the Ctrl-Home command should return the active axis back to home but what I get is a message about wanting to re-home that axis. What is the command the return the active axis back to the set home position? Thank you,
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
08 Dec 2016 18:51 #83792 by Todd Zuercher
Replied by Todd Zuercher on topic Return to Home Command
There isn't one. But an mdi command to move an axis back to it's origin would be G0 G53 X0 (for the X-axis)
To do XYZ would be g0g53x0y0z0.
08 Dec 2016 19:39 #83796 by Mike29
Replied by Mike29 on topic Return to Home Command
Thank you, I will give that a try.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
08 Dec 2016 19:59 #83800 by Todd Zuercher
If you really want a button on screen to press, you could add one in a pyvcp or gladevcp. Then use that button to trigger a HaluiMDI command.
I have made such additions to several of our machines. On these I made short sub program that is called by the haluimdi command. It sends the Z to its home, then the X and Y, and then turns off the spindle and resets any other important modal G-codes to the state I want them in for starting a new file.
08 Dec 2016 20:03 #83803 by Rick G
Time to create page: 0.357 seconds
