Need help with positioning problem
15 Dec 2016 02:36 #84138 by Ivan_The_Red
Need help with positioning problem was created by Ivan_The_Red
When i enter an mdi command to move an axis at feedrate of 30 ipm my machine moves smoothly to the commanded position however if i issue the same command but use a feedrate of 50ipm my machine still moves smoothly but does not make it to the commanded position. The dro says it does but it falls short of the physical movement.What values in fhe .ini file should i be looking at in order to correct this.I ran the latency program and feel comfortable with that value. Im using gecko g320x drives. Im also running mach3 and the machine works fine with that software so i also feel confident in the mechanics of the machine.
  • Moderator
  • Moderator
15 Dec 2016 02:44 #84140 by tommylight
Replied by tommylight on topic Need help with positioning problem
More info would be helpful, but start by setting the step timing to a higher value in stepconfig, if you are using the parallel port for machine control.
If you are getting real time errors, you will have to use set a bigger value for base thread.
15 Dec 2016 02:50 #84141 by Ivan_The_Red
Replied by Ivan_The_Red on topic Need help with positioning problem
Thanks for the suggestion , ill give that a shot tomorrow night.....wish me luck , mach3 has to go
  • Moderator
  • Moderator
15 Dec 2016 12:07 #84157 by tommylight
Good luck !
I avoid Mach as much as humanly possible.
Time to create page: 0.075 seconds
