i lost my tool change dialog box
16 Dec 2016 00:26 #84233 by Ivan_The_Red
i lost my tool change dialog box was created by Ivan_The_Red
Ive modified the standard gscreen gui and when im in mdi mode and enter a t1m6 the tool change confirmation dialog box doesnt show up.Anybody have any idea how that might have happened and how i can fix it ?
16 Dec 2016 01:41 #84241 by andypugh
Replied by andypugh on topic i lost my tool change dialog box
Do you still have the commands here in at least one of the HAL files specified in the INI file?
github.com/LinuxCNC/linuxcnc/blob/master...manualtoolchange.hal
16 Dec 2016 02:22 #84244 by Ivan_The_Red
Replied by Ivan_The_Red on topic i lost my tool change dialog box
Yah , theyre still there.
16 Dec 2016 06:01 #84253 by cmorley
Replied by cmorley on topic i lost my tool change dialog box
Gscreen usually uses it's own toolchange dialog.
it could possible be hidden under gscreen.
Without knowing what you modified hard to say what is going on.
What did you change that made it not work?
Posting your files would probably help.
Chris M
17 Dec 2016 00:58 #84299 by Ivan_The_Red
I found the problem , i had a bad value in one of my hal files....all is well now
17 Dec 2016 08:30 #84312 by cmorley
excellent.
Are your modifications to gscreen extensive?
I'm always curious on what people have done with gscreen.
Chris M
17 Dec 2016 14:16 #84325 by Ivan_The_Red
I think they are , i modified it more for the way my machine is built and for the type of work i do. I have a bridgeport boss that i do alot of "one offs " and manual type work with. i just got it to the point where i can run a program but now ive found some bugs that i need to work out then ill be glad to share it. Im migrating from mach3 and i have alot to learn not only about linuxcnc but linux as well. Are you the original author of gscreen ?
17 Dec 2016 16:55 #84328 by cmorley
yes I built gscreen.
Chris M
17 Dec 2016 20:00 #84337 by Ivan_The_Red
I really liked thst gui , as a matter of fact it had a big influence on my decision to move away from mach3 . right out of the box it was almost everything i needed so i decided to learn how to build off of what you did. I dont think i could have succeeded without your code to work with. For whatever its worth "Thanks Alot " I really do appreciate it.
18 Dec 2016 07:35 #84353 by cmorley
Your thank you is much appreciated.
I'm glad gscreen has been useful to you.
Chris M
Time to create page: 0.114 seconds
