- Thank you received: 338
Biesse Rover 346 Retrofit
9 years 9 months ago #86293
by bevins
This doesnt work either.
Replied by bevins on topic Biesse Rover 346 Retrofit
PCW wrote: probably more like:
loadrt hm2_pci config="num_encoders=6 sserial_port_0=003xxx sserial_port_1=0000xxxx use_serial_numbers=1"
9 years 9 months ago #86296
by bevins
at the halcmd: prompt, I can run the loadrt hostmot2 use_serial_numbers=1
Then when I try loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx sserial_port_1=00000000"
I get the error.
I get the error.
9 years 9 months ago - 9 years 9 months ago #86297
Replied by PCW on topic Biesse Rover 346 Retrofit
Andys method works for me:
halcmd: loadrt hostmot2 use_serial_numbers=1
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="10.10.10.10"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:12:ab:cd
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
This is linuxCNC V 2.7.8
Last edit: 9 years 9 months ago by PCW.
9 years 9 months ago #86298
by bevins
I am on 2.8 pre. IS it broken in 2.8 pre?
9 years 9 months ago - 9 years 9 months ago #86299
I doubt anything has changed in the driver between 2.7 and 2.8
It may be more likely that there's a bug with the use_serial_numbers option
and more than 1 sserial port since this is uncommon setup (more than 8 channels total)
You might also try only enabling the sserial channels that you actually have connected
probably something like sserial_port_0=00x sserial_port_1=00xxxxxx
9 years 9 months ago #86301
Replied by tommylight on topic Biesse Rover 346 Retrofit
Just a remark, in your pictures i can see 7i77 and 7i70 are working properly but 7i74 has no green light on, i am sure on mine it is on full when active.
But 7i70 works through it, so..........
Time to create page: 0.356 seconds
