andypugh wrote: I prefer the alternative scheme.
You enable it in the "loadrt hostmot2" line in the HAL.Code:loadrt hostmot2 use_serial_numbers=1
PCW wrote: A couple things:
The 7I74s RJ45 lights are not functional
All sserial cards use straight through Cat5E/Cat6 cables
The likely reason the 7I70/7I71 cards do not start is that they have not been enabled in the hal file
(since there are more than 8 sserial ports in the config there are 2 sserial ports, port_0 (3 7I77 channels only)
and port_1 (8 channels on 7I74) Port 1 must be specifically enabled in the hal file
