- Thank you received: 338
tommylight wrote: Yes there is. There are two power lines on the field power connector, there is a Vin on pin 5 and Vfield on pins 1 2 3 4. The 5V is logic power so I always use separate power for it.
PCW is welcomed to chime in about this as I got the Mesa cards 2 days ago and so far I only tested the 7i76 on the bench ( well living room table ), but from experience it should be like that.
There is the W1 jumper that has to be set to the right for use with separate power supplies on the Field power connector.
bevins wrote: So setting W1 to the right hand position, VIN becomes logic power, then I bring in another source of 24vdc to TB2 pin 1,2,3 or 4 then pin 8 for ground. That way my field power is isolated from the board logic power?
So I could use the existing 24vdc unregulated power for outputs and inputs?
Is that the scenario?
