Biesse Rover 346 Retrofit
9 years 10 months ago #84900 by tommylight
Sleep ???? What is this "sleep" you talk about???
It is 6:24 AM here and i have yet to catch some zzzzzzzzzz .............in an hour or two.
It is nice to see the progress you are making.
Regards,
Tom
9 years 10 months ago #85006 by bevins
Replied by bevins on topic Biesse Rover 346 Retrofit
OK, so The machines limit switches go directly to the servo drives I imagine to shutoff the motion.
I want them to go to Linuxcnc also, so Is there an issue with energizing a relay for each limit switch and sending one contact into Linuxcnc and the other into the drive or should I leave it the way it is? I would obviously leave the switches N/C so the relay is on all the time in case of wire breakage it will trip.
Is this done this way normally or leave it directly attached to the servo drives?
9 years 9 months ago #85124 by andypugh
Replied by andypugh on topic Biesse Rover 346 Retrofit
bevins wrote: Is there an issue with energizing a relay for each limit switch and sending one contact into Linuxcnc and the other into the drive
I don't see any reason to bother with a relay, if it is a voltage-level signal can simply connect to both LinuxCNC and the drive.
9 years 9 months ago #85125 by bevins
It is different power supplies from different sources and I dont know if there is a voltage differential between the two. I would rather keep them seperate.
I could just bring in the nput to the 7i77 as Limit switch, and fire an output to go to the drive.
9 years 9 months ago #85201 by andypugh
bevins wrote: It is different power supplies from different sources and I dont know if there is a voltage differential between the two. I would rather keep them seperate.
Using 7i77 general-purpose outputs to the drive is likely to have the same problem with not-common GND, and has no advantage over just having the existing software-controlled amp-enable controlling the drive with the limit switch input to the drive hard-wired (or left open, depending on logic). The amp-enable outputs (ENA- / ENA+) on the 7i77 act as switches, so common-GND is not required.
9 years 9 months ago #85257 by beltramidave
bevins wrote:
beltramidave wrote: The Rovers are good machines. We have many of the different Biesse models (including the 346) where I used to work (and still do contract work). May be able to find a schematic/manual for it, unfortunately, they are Christmas shutdown now.
Dave
That would make my day if I could find schematics......
I sent you a email through this forum. I have a schematic and manual for you, just need your address and they will send it to you.
Time to create page: 0.139 seconds
