Plasma Questions
9 years 10 months ago #85016 by islander261
Replied by islander261 on topic Plasma Questions
Hello
The documents say that the interpreter converts all chars to upper case. I have tried both cases with the same results.I was just trying to keep like source parameters together. Machine hardware related parameters coming from the .ini, GUI related parameters coming from the .hal files and the part related parameters coming in on the G code file.
9 years 10 months ago #85019 by andypugh
Replied by andypugh on topic Plasma Questions
Have you set the feature mask to allow INI access?
9 years 10 months ago #85031 by islander261
Andy
Thank you, my bad for not reading the entire instructions. Having the FEATURES = 12 in my .ini file fixed this.
9 years 9 months ago #85184 by grijalvap
Replied by grijalvap on topic Plasma Questions
hi do you think it is possible to make a THC using the analog to digital card from mesa
store.mesanet.com/index.php?route=produc...83_88&product_id=126
can it be more accurate?
9 years 9 months ago #85197 by andypugh
grijalvap wrote: hi do you think it is possible to make a THC using the analog to digital card from mesa
Mesa do a dedicated THC card. (actually, two of them)
store.mesanet.com/index.php?route=product/search&search=THCAD
9 years 9 months ago #85209 by islander261
Hello
I am using the THCad card from Mesa. So far I haven't used it with the plasma table as my control is still under construction. Seams to be plenty stable over the voltage range I need it work in.
Progress, I have my system probing for the top surface of the sheet and going to the set pierce height set from the GUI. This also means the new Z axis is functioning with limits and homing. Now I need to get the external Estop figured out along with reading control settings out of the Sheetcam generated Gcode file as generated by the CandCNC PP. I really only need a subset of the parameters because I don't have a fancy Hypertherm power supply that can be adjusted on the fly via a serial connection. I will post progress shortly.
Off to a trade show and selling for the rest of the week.
Time to create page: 0.323 seconds
