Hello
Thank you for the replies.
tommylight
Yes, I really am trying to push the complication on this. I have a THCad board installed and actually plan on using JT's THC component for some early testing. I am aware the the update rate of the THC comp using a THCad board is nearly an order of magnitude faster than the commercial units and much faster than the mechanics of the Z axis stage. I am really looking for input from the group from people that actually use this setup. I fully expect to hear that I am wasting my time and that this approach will work so much better than my old Torchmate AVHC there is no need to change anything. I cut about 1,000lbs (454kg) of 14ga (1.9mm) HR steel sheet per month, not much by your job shop standards buy plenty for one semi retired guy.
Rick G
Yes. I have a Duramax torch and use the Finecut consumables so my typical cut parameters for 14ga HR steel are:
45A Cut current
220 in/min cut speed
.1g (about 37in/s/s) acceleration on X&Y (really too slow but all the better my cheap table will do reliably)
.09" pierce height
.07" initial cut height
While this is a slight departure from the Hypertherm cut charts it is where I get my best cut quality with my equipment YMMV.
The measured arc voltage into a long straight cut @ .07" height is about 80V on my old Torchmate AVHC and confirmed using a DMM. So 80V / .07inch = 1142.857 Volts/inch *.005 inches = 5.7V voltage change for a .005" change in cutting height if all other parameters are fixed.
I cut mostly artsy and decorative panels and often don't have enough space for longish tangential lead ins and lead outs on the interior cuts. Using the correct length lead in is a great way to compensate for torch acceleration and arc stabilization for rectilinear engineering pieces.
rodw
I know this will start a real fire. If you plan on using your system for even semi commercial work be sure to use a real machine torch and power supply from a US or Western European supplier (Hyperthrem, ESAB, TD are the ones that come to mind). If you don't you'll wish you did! Build your table as stiff as you can afford and make sure you can get at least .1 g acceleration at speed without shaking the torch. Thin materials (< 3mm) need high speed and acceleration for good cuts.
I am looking for decoding of the operators or notation of the two specific lines of HAL code I posted earlier. I have found no other examples of this notion and don't understand it. I get the whole general HAL nets and pin thing for connecting signals.
forum.linuxcnc.org/plasma-subroutines-library
Again thank you everyone for your comments.
