Plasma Questions
9 years 6 months ago - 9 years 5 months ago #90871 by LulaNord
Replied by LulaNord on topic Plasma Questions
Hi....there are 2 sub routines for finding the plate in the wiki, there is one more made by BigJT and there is one that comes with gcodetools for Inkscape under the tools library. I personally do not use any of them,I have all that implemented in hal .
Also for the third question, the pierce height is always higher than the cut height so after getting the arc OK signal and starting the move on the x/y plane it takes a short time to get to cut height while the torch is moving. So there are 2 factors you can use to achieve what you describe under number 3.
prototype pcb assembly
Last edit: 9 years 5 months ago by LulaNord.
9 years 6 months ago #90876 by tommylight
Replied by tommylight on topic Plasma Questions
LulaNord wrote: Hi....there are 2 sub routines for finding the plate in the wiki, there is one more made by BigJT and there is one that comes with gcodetools for Inkscape under the tools library. I personally do not use any of them,I have all that implemented in hal .
Why is this a copy/paste from a post made earlier by me???
Is there a question that i missed somewhere?
9 years 5 months ago #92548 by grijalvap
Replied by grijalvap on topic Plasma Questions
Hi I finally get the MESA 7I87 analog input card but, but I saw in the mesa driver there is not support for this serial card
Do you know if there is any plan to include this card in the driver
is nay walk around I can implement.
9 years 5 months ago #92550 by andypugh
Replied by andypugh on topic Plasma Questions
_All_ smart-serial cards ought to work. Part of the point of smart-serial is that no special drivers are needed for any card of that type.
Just plug it in, it will work.
9 years 5 months ago #92551 by grijalvap
It is what I did but not work, actually I see SSPORT in Hal components bun I haven't seen any input output pin.
I can check again this afternoon.
9 years 5 months ago #92553 by PCW
Replied by PCW on topic Plasma Questions
Yes, as long the 7I87 is powered and connected to a sserial port on the host it should just
work.
A red light on the 7I87 means power is on but no communications are running.
A blinking green light means communications are running
There is deliberately no specific card support for sserial devices on the linuxCNC side
as the cards are supposed to be detected and proper hal pins created based on information read from
the remote sserial card itself.
Time to create page: 0.172 seconds
