Z-axis home position
23 Dec 2016 12:09 #84607 by timmert
Z-axis home position was created by timmert
Hi
I have a question about the homing sequence. I'm not sure which config line to edit.
The Z-axis is going upwards and hits the switch and then returns +/- 50% down. And that's the home position.
It works fine but when I run a program it will go to home first and then starts its program. That's not perfect because it can crash into the part when going to home.
So my question is, how can I move the home position for the Z axis up?
23 Dec 2016 18:09 #84640 by BigJohnT
Replied by BigJohnT on topic Z-axis home position
Set the home position to just off the switch in your ini file.
linuxcnc.org/docs/2.7/html/config/ini-homing.html#_home_offset
JT
24 Dec 2016 13:20 #84670 by timmert
Replied by timmert on topic Z-axis home position
Thanks John,
It was the home offset setting.
It was set to 100, but I changed it to a lower value to test and it works fine :)
I set it to 0 in the end
