linuxcnc
9 years 10 months ago #84866
by davidcnc
I have been using since April 2013 ( ubuntu 10.04 LTS) Live version on all my conversions.
All the old sites have changed formats since 2013.
What is the newest live up dated version that is proven ready to use??
And which download site do I use??
My only problem is the dam popup screens telling me I no longer have support if plugged into the net.
David Nichols
David Nichols
- Thank you received: 1480
9 years 10 months ago #84897
Replied by Todd Zuercher on topic linuxcnc
The current Linuxcnc Live CD is based on Debian 7 (Wheezy) and is Linuxcnc V 2.7. It can be downloaded here.
www.linuxcnc.org/linuxcnc-2.7-wheezy.iso
As to the problems running the software updater with Ubuntu 10.04, you can fix that by changing the Ubuntu repos like this.
www.mesaus.com/info/lucid-sources.txt
- eFalegname
- Thank you received: 30
9 years 10 months ago #84906
by eFalegname
Replied by eFalegname on topic linuxcnc
Debian 7 (Wheezy) LinuxCNC V 2.7 is an ugly beast and must die.
forum.linuxcnc.org/9-installing-linuxcnc...rtai?start=100#84899
9 years 10 months ago - 9 years 10 months ago #84910
Debian 7, while a little annoying at times, isn't quite that bad. It is probably about as much if not more hassle to install Linuxcnc on Mint 18 as it is to smooth out the wrinkles in Wheezy.
Last edit: 9 years 10 months ago by Todd Zuercher.
Time to create page: 0.101 seconds
