Computer Shutdown
- babinda01
29 Dec 2016 22:47 #84883
by babinda01
Computer Shutdown was created by babinda01
Hello
I am just commencing a retrofit of a milling machine. I am trying to decide on a UI to use - at the moment I am tossing up between Gmoccapy and a custom GScreen.
My first question......is there a way to shut down the pc when you exit Linuxcnc. For example, if I am using Gmoccapy, and I click the exit button in the lower right corner, it would be great if it could shut down Linuxcnc and then shut down the PC.
Andrew
Andrew
- newbynobi
- Thank you received: 394
29 Dec 2016 23:07 #84885
by newbynobi
Replied by newbynobi on topic Computer Shutdown
I can imagine two solutions
1. Change gmoccapy code to execute the shutdown command.
2. Use a bash script to start ljnuxcnc and wait until linuxcnc stops and send then the shutdown command.
But i have never done that.
Norbert
Norbert
The following user(s) said Thank You: Moutomation
- babinda01
29 Dec 2016 23:19 #84886
by babinda01
Replied by babinda01 on topic Computer Shutdown
Hi Norbert
Thanks - I will try the bash script first, as I am a little more comfortable doing that.
Andrew
Andrew
- Moutomation
- Thank you received: 11
24 Aug 2024 09:59 #308526
by Moutomation
Replied by Moutomation on topic Computer Shutdown
Hello,
I use gmoccapy. When I turn on the machine, the computer starts first, then gmoccapy. How can I shut down Linuxcnc first and then the computer when I press an external key?
Can I do this with a button on the machine?
- SamCoffee
- Visitor
26 Aug 2024 02:22 #308637
by SamCoffee
I think you could script the HAL file to configure the external button to shut down LinuxCNC first, then the computer, and link the button to both functions in that order.
Replied by SamCoffee on topic Computer Shutdown
Hello,Hello,
- Moutomation
26 Aug 2024 11:33 #308691
by Moutomation
I don't know how to do this
- MennilTossFlykune
- Thank you received: 30
26 Aug 2024 12:30 - 27 Aug 2024 10:00 #308695
by MennilTossFlykune
Replied by MennilTossFlykune on topic Computer Shutdown
You could launch LinuxCNC with a script like so
and connect the pin gmoccapy.h-button.button-9, which exits gmoccapy, to an external button.
#!/bin/bash
linuxcnc '/home/yourusername/linuxcnc/configs/yourconfig/yourconfig.ini'
systemctl poweroffand connect the pin gmoccapy.h-button.button-9, which exits gmoccapy, to an external button.
Last edit: 27 Aug 2024 10:00 by MennilTossFlykune.
The following user(s) said Thank You: Aciera, Moutomation
- Thank you received: 2176
26 Aug 2024 13:11 #308701
Replied by Aciera on topic Computer Shutdown
This seems to work for me:
#!/bin/bash
linuxcnc '/home/yourusername/linuxcnc/configs/yourconfig/yourconfig.ini' && systemctl poweroff
The following user(s) said Thank You: MennilTossFlykune, Moutomation
- SamCoffee
- Visitor
28 Aug 2024 06:25 - 11 Sep 2024 06:18 #308874
by SamCoffee
how is it going?
Last edit: 11 Sep 2024 06:18 by SamCoffee.
28 Aug 2024 06:36 - 28 Aug 2024 06:49 #308876
Are you asking me how it works or are you asking the OP if it works for him?
[edit]
'&&' means that the second command (ie 'systemctl poweroff') is only executed once the first command (ie 'linuxcnc '/home/yourusername/linuxcnc/configs/yourconfig/yourconfig.ini') has been successfully executed, which is only the case once linuxcnc has been shutdown again.
Useful if you want a one line command.
[edit2]
in comparison '&' will run both commands independently
[edit]
[edit2]
Last edit: 28 Aug 2024 06:49 by Aciera.
Time to create page: 0.559 seconds
