"Toggle machine power" button and "joint 2 following error" issues
9 years 10 months ago #84893 by Birddogs
Looking for some help...
This is not a running system but a new conversion to Linux cnc Bridgeport cnc milling machine.
I am novice at Linux cnc. (am over my head in the hundreds of pages of documentation)
issues at hand,
1, toggle machine power button > homing section is greyed out. (Machine does come out of estop mode, Peter got me through that issue)
2, I am getting a "joint 2 following error" from what I have researched, it is probably in my ini file. Could someone take a look and see if there is something I need to change/edit. or if you need more information to determine let me know.
# Basic 5i25/7i77 ini file
[EMC]
MACHINE = 7i77
DEBUG = 0
[DISPLAY]
DISPLAY = axis
PYVCP = tabs.xml
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
# the next line will need to be modified to point to the nc_files folder
PROGRAM_PREFIX = /home/randy/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = 7i77.var
[EMCMOT]
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
HALFILE = 7i77.hal
POSTGUI_HALFILE = postgui.hal
HALFILE = jog-pendant.hal
HALUI=halui
[HALUI]
MDI_COMMAND = G0 G53 Z0
MDI_COMMAND = G0 G53 X0Y0Z0
MDI_COMMAND = G0 X0Y0
MDI_COMMAND = G0 Z0
[TRAJ]
#edited axis to 3 from original 4
AXES = 3
#edited coordinates removed A
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.20
MAX_LINEAR_VELOCITY = 1.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
#### the axis values need to be updated to your machine
[AXIS_0]
TYPE = LINEAR
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 4.0
BACKLASH = 0.000
FERROR = 0.050
MIN_FERROR = 0.01
# put how many pulses from the encoder per inch here
#1000=-40000,250=10000,1024=40960,500=20000
INPUT_SCALE = -10000
OUTPUT_SCALE = 1.000
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 1.0
MIN_LIMIT = -.45
MAX_LIMIT = 17
HOME = 0.000
HOME_OFFSET = .05
HOME_SEARCH_VEL = 0.5
HOME_LATCH_VEL = 0.10
# the X axis encoder has an index channel, so we use it to improve the home accuracy
HOME_USE_INDEX = YES
HOME_IGNORE_LIMITS = YES
# PID tuning params
DEADBAND = 0.000015
P = 20
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.01
BIAS = 0.000
[AXIS_1]
TYPE = LINEAR
MAX_VELOCITY = 1.0
BACKLASH = 0.000
FERROR = 0.050
MIN_FERROR = 0.01
INPUT_SCALE = 10000
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 1.0
MIN_LIMIT = -2
MAX_LIMIT = 11.5
HOME = .0
HOME_OFFSET = 0.05
# the Y axis encoder has an index channel, so we use it to improve the home accuracy
# PID tuning params
DEADBAND = 0.00015
P = 20
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.01
BIAS = 0.000
[AXIS_2]
TYPE = LINEAR
MAX_VELOCITY = 1.0
BACKLASH = 0.000
FERROR = 0.050
MIN_FERROR = 0.01
INPUT_SCALE = 10000
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 1.0
MIN_LIMIT = -4.75
MAX_LIMIT = .25
HOME = .0
HOME_OFFSET = 0.05
# the Z axis encoder does not have an index channel, so we have to home without index
# PID tuning params
DEADBAND = 0.00015
P = 20
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.01
BIAS = 0.000
#[AXIS_3]
#TYPE = LINEAR
#MAX_VELOCITY = 1.0
#MAX_ACCELERATION = 4.0
#BACKLASH = 0.000
#FERROR = 0.050
#MIN_FERROR = 0.01
#INPUT_SCALE = 40960
#OUTPUT_SCALE = 1.000
#OUTPUT_OFFSET = 0.0
#MAX_OUTPUT = 1.0
#MIN_LIMIT = -5.0
#MAX_LIMIT = 5.0
#HOME = 0.0
#HOME_OFFSET = 1.9
#HOME_SEARCH_VEL = 0.0
#HOME_LATCH_VEL = 0.0
#HOME_FINAL_VEL = 0.0
# the A axis encoder does not have an index channel, so we have to home without index
#HOME_USE_INDEX = YES
#HOME_IGNORE_LIMITS = YES
# PID tuning params
#DEADBAND = 0.000015
#P = 150
#I = 0
#D = 0
#FF0 = 0
#FF1 = 1.4
#FF2 = 0.01
#BIAS = 0.000
9 years 10 months ago - 9 years 10 months ago #84902 by tommylight
If you did that config with pnconfig, you have to edit it manualy as it adds a 0 at the end "input_scale" parameter.
I did a 7i76E config and i know i had to remove a lot of 0.
Do you actualy have 2500 cpr encoders? If yes, then it looks all good.
This is not your error, as i can see writen above the input_scale the sample values, and they do not make sense i.e. 1000pulses is equal to 40000 !!! It should be 4000, i am sure. Or i missed the part where a quadrature encoder can be read at 40 values per pulse.
Please do give that a try and let us know if it works out.
Again this is not the only problem why you are getting that error, but do check it.
Regards
Last edit: 9 years 10 months ago by tommylight.
9 years 10 months ago #84935 by Birddogs
I did not configure the files, they were copied from the same type of mill that was running the same drives (one of the guys on this forum).
I do not have documentation of encoders, they are original 1985 Bridgeport equipment.
I do believe they are Deferential. 3 v between A, _A. 3 v between B, -B
I changed "input_scale" from 10000 to 1000 on all three axes.
no change, still getting error.
Drives are powered and belts are removed from DC motors.
Motors are not calibrated, (they are rough tuned through drives. motors are creeping very slow)
I thought the motors would lock static, when I came out of estop. they don't stop creeping..
any ideas for what to do next?
9 years 10 months ago #84943 by PCW
Do the encoders work (does the LinuxCNC DRO work?)
9 years 10 months ago #84945 by Birddogs
DRO does work.
I put belt on Y axis to check:
actual distance traveled vs DRO readout travel.
"input_scale" set at 10000
bed of mill moved ~ 1" and DRO readout moved ~1"
Motor turn of one revolution = .1" of bed travel and .1" DRO display change.
I had tried "input_scale" set at 1000 but that resulted in bed mill moved ~1" DRO reading of ~10.3" (1000 is incorrect.)
9 years 9 months ago #85122 by Birddogs
Update on some findings.
My encoders are 250 lines per revolution.
my pulley reduction is 2/1
5 pitch screw (0.2" per revolution)
0.0004" per encoder line.
Time to create page: 0.385 seconds
