inhibit Machine turning on
- Thank you received: 7468
08 Jan 2017 17:59 #85484
Replied by tommylight on topic inhibit Machine turning on
Its all good then.
Regards.
Regards.
- Thank you received: 1472
08 Jan 2017 22:20 #85494
Replied by Todd Zuercher on topic inhibit Machine turning on
Often in the case of the drive having separate inputs such as that, each limit input will inhibit movement in one direction, and the e-stop input disables all movement and sets the brake if applicable.
- bevins
- Thank you received: 338
09 Jan 2017 12:40 - 09 Jan 2017 12:40 #85512
by bevins
Replied by bevins on topic inhibit Machine turning on
And the final estop startup circuit done. see attached.
Last edit: 09 Jan 2017 12:40 by bevins.
- Benb
- Thank you received: 61
09 Jan 2017 17:13 #85531
by Benb
Replied by Benb on topic inhibit Machine turning on
The wiring diagram looks fine and it will serve as good reference for the next person that needs to hard-wire Estop and safety switches with annunciation indication on the screen.
Time to create page: 0.095 seconds
