Accumulated travel distance for axes
9 years 9 months ago #85591 by Todd Zuercher
Glad to hear it works. I wonder why the saveparam component or something like it has never been added to the main release? Seems like it could be occasionally useful, without much impact on existing code.
9 years 9 months ago #85592 by perra_e
I wonder the same thing. Maybe it's so simple that no one has written documantation?
Very usefull indeed!
Thanks a lot for your support. This function was extremely valuable to me :)
5 years 7 months ago - 5 years 7 months ago #201953 by HansU
I added the functionality in Norberts timer-VCP (Glade). See: forum.linuxcnc.org/gmoccapy/40709-gmocap...lock?start=30#201950
I think it's easier to set up than the solution with paramsaver.
You can also include this VCP in other GUIs than gmoccapy.
In AXIS you can integrate it with following entry in the INI-file
[DISPLAY] EMBED_TAB_NAME = Counter EMBED_TAB_COMMAND = gladevcp -x {XID} -u counter.py -H counter.hal counter.glade
Then it would look like this
Last edit: 5 years 7 months ago by HansU.
The following user(s) said Thank You: arvidb
5 years 7 months ago #201962 by itsme
Are the values saved or will they be reset after Power cycling?
5 years 7 months ago #202074 by HansU
They are all saved in a *.var file except the value "Program Running Time".
The following user(s) said Thank You: itsme
Time to create page: 0.059 seconds
