Radius to End differ from Radius to Start Error During Stop/Run from line.
9 years 9 months ago #85695 by mjtooba
Hi guys
with normal axis gui and simulated environment i see start/end Radius error if i press STOP on arc and then Run From selected line. is there any solution that solve this problem and we could stop during g2,g3 and move by keep current line ?
9 years 9 months ago - 9 years 9 months ago #85791 by andypugh
Unfortunately not. You need to find a line before the arc mode that moves to a well-defined position.
I typically look for a G0 move.
An arc move without a well-defined start can't be made.
Last edit: 9 years 9 months ago by andypugh.
9 years 9 months ago #85804 by mjtooba
after some digging in source code , i found a solution by modifying code , now it is possible to stop and continue on G2 G3 without any Error.
i am not yet very familiar with git push and ... , so i just explain what i did for others
for reference :
disable update interp position in interp.synch() in beginning during run from line fixed problem.
by disabling update position , the parser get start of arc position from previous line not from current position.
this solved problem but not sure about side-effects.
8 years 6 months ago #109300 by Skidloaders1
Good day MJtooba
could you explain this a little more please rgds Wilfried
Time to create page: 0.316 seconds
