Why on my lathe G61 does not work on circles?
  • pkasy
  • pkasy's Avatar Topic Author
  • Premium Member
  • Premium Member
25 Jan 2017 04:01 - 25 Jan 2017 04:03 #86591 by pkasy
Hello everybody!
Here's a picture of it.
Draws correctly and in the program indicated G61 and even G61.1.
But there is a straight line from start point to end point.
Here is a code:
N298 G3 X--56.794 Z[-2.843-0.2] R129.474
The R(radius in mm) is not so much to be a line, right?
As you can see, the white color shows the desired path, and red that happened. 2 times. This I rechecked.
I have a simple question - why?
Last edit: 25 Jan 2017 04:03 by pkasy.
25 Jan 2017 13:39 #86612 by andypugh
Replied by andypugh on topic Why on my lathe G61 does not work on circles?
Can you show us all the G-code?
  • pkasy
  • Premium Member
  • Premium Member
25 Jan 2017 16:25 #86637 by pkasy
sure
Warning: Spoiler!
25 Jan 2017 17:35 #86642 by andypugh
I can't reproduce the problem here, but I did need to set G18 (XZ plane) and G7 (diameter mode) for it to make sense.
Can you repeat with a G18 and G7 (and no material, just in case)
  • pkasy
  • Premium Member
  • Premium Member
25 Jan 2017 22:57 - 25 Jan 2017 23:14 #86656 by pkasy
G18 and G7 is in INI file.
[RS274NGC]
RS274NGC_STARTUP_CODE = G18 G21 G90 G7 G95
If I put G17 in my file I will see lines, not arcs.
So G18 was active.
Last edit: 25 Jan 2017 23:14 by pkasy.
25 Jan 2017 23:48 #86664 by andypugh
Do they show up in active G-codes in the MDI tab of Axis?
  • pkasy
  • Premium Member
  • Premium Member
26 Jan 2017 01:17 - 26 Jan 2017 01:32 #86670 by pkasy
Yes.
Usually arcs work fine. But not this time.
Last edit: 26 Jan 2017 01:32 by pkasy.
26 Jan 2017 01:35 #86674 by andypugh
I am rather puzzled, then, to be honest.
But, I can't reproduce the problem here.
Perhaps a feature of your machine settings?
What version of LinuxCNC are you using?
  • pkasy
  • Premium Member
  • Premium Member
26 Jan 2017 02:21 - 26 Jan 2017 02:24 #86678 by pkasy
2.7.8
It draws correctly, but performs incorrectly.
Last edit: 26 Jan 2017 02:24 by pkasy.
  • pkasy
  • Premium Member
  • Premium Member
26 Jan 2017 07:29 - 26 Jan 2017 07:31 #86690 by pkasy
I ran the program several times and that's what I saw.
after the first run of program, G18 changes to G17.
and the second run is going incorrect, but the graphics is correct, because the program does not reloaded.
It is a mistake in the Axis.
Last edit: 26 Jan 2017 07:31 by pkasy.
Time to create page: 0.449 seconds
