Why on my lathe G61 does not work on circles?
- pkasy
- Thank you received: 5
25 Jan 2017 04:01 - 25 Jan 2017 04:03 #86591
by pkasy
Why on my lathe G61 does not work on circles? was created by pkasy
Hello everybody!
Here's a picture of it.
Draws correctly and in the program indicated G61 and even G61.1.
But there is a straight line from start point to end point.
Here is a code:
N298 G3 X--56.794 Z[-2.843-0.2] R129.474
The R(radius in mm) is not so much to be a line, right?
As you can see, the white color shows the desired path, and red that happened. 2 times. This I rechecked.
I have a simple question - why?
Here is a code:
Last edit: 25 Jan 2017 04:03 by pkasy.
- Thank you received: 4652
25 Jan 2017 13:39 #86612
Replied by andypugh on topic Why on my lathe G61 does not work on circles?
Can you show us all the G-code?
- pkasy
25 Jan 2017 16:25 #86637
by pkasy
Replied by pkasy on topic Why on my lathe G61 does not work on circles?
sure
Warning: Spoiler!
G61
N6 M5
N8 M6 T01 G43
N10 G96 G0 X--64 Z3 M3 S150 D2250
N12 ()
N14 (-----------------)
N16 (TR-CONTOUR - TURN)
N18 (-----------------)
N20 G95
N22 X--64 Z3
N24 X--59.2
N26 G1 Z-13.192 F0.1 M8
N28 X--59.602 Z-12.992
N30 G0 Z3
N32 X--57.2
N34 G1 Z-2.953
N36 X--57.6 Z-2.753
N38 G0 Z3
N40 X--55.2
N42 G1 Z-2.732
N44 X--55.6 Z-2.532
N46 G0 Z3
N48 X--53.2
N50 G1 Z-2.52
N52 X--53.6 Z-2.32
N54 G0 Z3
N56 X--51.2
N58 G1 Z-2.316
N60 X--51.6 Z-2.116
N62 G0 Z3
N64 X--49.2
N66 G1 Z-2.12
N68 X--49.6 Z-1.92
N70 G0 Z3
N72 X--47.2
N74 G1 Z-1.932
N76 X--47.6 Z-1.732
N78 G0 Z3
N80 X--45.2
N82 G1 Z-1.752
N84 X--45.6 Z-1.552
N86 G0 Z3
N88 X--43.2
N90 G1 Z-1.581
N92 X--43.6 Z-1.381
N94 G0 Z3
N96 X--41.2
N98 G1 Z-1.417
N100 X--41.6 Z-1.217
N102 G0 Z3
N104 X--39.2
N106 G1 Z-1.262
N108 X--39.6 Z-1.062
N110 G0 Z3
N112 X--37.2
N114 G1 Z-1.114
N116 X--37.6 Z-0.914
N118 G0 Z3
N120 X--35.2
N122 G1 Z-0.974
N124 X--35.6 Z-0.774
N126 G0 Z3
N128 X--33.2
N130 G1 Z-0.843
N132 X--33.6 Z-0.643
N134 G0 Z3
N136 X--31.2
N138 G1 Z-0.719
N140 X--31.6 Z-0.519
N142 G0 Z3
N144 X--29.2
N146 G1 Z-0.603
N148 X--29.6 Z-0.403
N150 G0 Z3
N152 X--27.2
N154 G1 Z-0.495
N156 X--27.6 Z-0.295
N158 G0 Z3
N160 X--25.2
N162 G1 Z-0.395
N164 X--25.6 Z-0.195
N166 G0 Z3
N168 X--23.2
N170 G1 Z-0.303
N172 X--23.6 Z-0.103
N174 G0 Z3
N176 X--21.2
N178 G1 Z-0.218
N180 X--21.6 Z-0.018
N182 G0 Z3
N184 X--19.2
N186 G1 Z-0.142
N188 X--19.6 Z0.058
N190 G0 Z3
N192 X--17.2
N194 G1 Z-0.073
N196 X--17.6 Z0.127
N198 G0 Z3
N200 X--15.2
N202 G1 Z-0.012
N204 X--15.6 Z0.188
N206 G0 Z3
N208 X--13.2
N210 G1 Z0.042
N212 X--13.6 Z0.242
N214 G0 Z3
N216 X--11.2
N218 G1 Z0.087
N220 X--11.6 Z0.287
N222 G0 Z3
N224 X--9.2
N226 G1 Z0.125
N228 X--9.6 Z0.325
N230 G0 Z3
N232 X--7.2
N234 G1 Z0.155
N236 X--7.6 Z0.355
N238 G0 Z3
N240 X--5.2
N242 G1 Z0.178
N244 X--5.6 Z0.378
N246 G0 Z3
N248 X--3.2
N250 G1 Z0.192
N252 X--3.6 Z0.392
N254 G0 Z3
N256 X--1.2
N258 G1 Z0.199
N260 X--1.6 Z0.399
N262 G0 Z3
N264 X-0.798
N266 G1 Z0.2
N268 X-0.4 Z0.4
N270 G0 X-0.8
N272 G1 Z0.267 F0.05
N274 Z0.1
N276 X-0.196
N278 G3 X--57.394 Z[-2.743-0.3] R129.474
N280 G1 X--57.718 Z-3.18
N282 X--58.6 Z-3.885
N284 Z-13.292
N286 X--64
N288 G0 Z2.1
N290 X-0.8
N292 G1 Z0.1 F0.05
N294 Z0
N296 X-0.796
N300 G1 X--57.118 Z-3.28
N302 X--58 Z-3.985
N304 Z-13.392
N306 X--64
N308 G0 Z2
M5
N312 M02
%Please Log in or Create an account to join the conversation.
25 Jan 2017 17:35 #86642
- pkasy
25 Jan 2017 22:57 - 25 Jan 2017 23:14 #86656
by pkasy
Last edit: 25 Jan 2017 23:14 by pkasy.
25 Jan 2017 23:48 #86664
Do they show up in active G-codes in the MDI tab of Axis?
- pkasy
26 Jan 2017 01:17 - 26 Jan 2017 01:32 #86670
by pkasy
Yes.
Usually arcs work fine. But not this time.
Last edit: 26 Jan 2017 01:32 by pkasy.
26 Jan 2017 01:35 #86674
I am rather puzzled, then, to be honest.
But, I can't reproduce the problem here.
Perhaps a feature of your machine settings?
What version of LinuxCNC are you using?
- pkasy
26 Jan 2017 02:21 - 26 Jan 2017 02:24 #86678
by pkasy
2.7.8
It draws correctly, but performs incorrectly.
Last edit: 26 Jan 2017 02:24 by pkasy.
- pkasy
26 Jan 2017 07:29 - 26 Jan 2017 07:31 #86690
by pkasy
I ran the program several times and that's what I saw.
after the first run of program, G18 changes to G17.
and the second run is going incorrect, but the graphics is correct, because the program does not reloaded.
It is a mistake in the Axis.
Last edit: 26 Jan 2017 07:31 by pkasy.
