i have an old Linuxcnc system with manual Toolchange which
behaves like t1 M6 and if next tool T2 M6 for instance the length difference of Tooltable is used
Now a very new Linuxcnc installation (the latest ISO Disk ) the T2 m6 requires an G43 to use the tool length compensation
so my question is that a change to Linuxcnc newer version or is there any hidden ini magic to change the behavior ?
in worst case we do need to change the post processor of the cam for the one machine and another for other machine ?
i use linuxcnc for a verry long time but that would help me a lot
thomas
Otherwise I don't know why the behavior may have changed for you. But for myself I consider it the best practice to explicitly state G43Hn after every tool change anyway.
