Native cam help with ini.file/ subroutine_path
9 years 9 months ago #86987 by Dougefresh
Maybe seeing your modified ini. File would help me to better understand.
9 years 9 months ago - 9 years 9 months ago #87010 by cncnoob1979
Here is my ini for axis. Look for my path's and how they are modified from yours. Be sure to follow the readme I linked. The display section is where you really need for ncam to embed into axis.
File Name: bridgeport...1-30.ini
File Size:7.9 KB
You must edit your ini file to reflect these changes. The ini that your machine uses to load linuxcnc.
Last edit: 9 years 9 months ago by cncnoob1979.
The following user(s) said Thank You: Dougefresh
9 years 9 months ago - 9 years 9 months ago #87031 by Dougefresh
I finally got ncam to load embedded when I start linux cnc. Im getting an g-code error when I try to load a work peice. Im positive I dont have a file in the right place...
Last edit: 9 years 9 months ago by Dougefresh.
9 years 9 months ago #87032 by cncnoob1979
Sounds like you don't have the paths correct for where ncam is located.
Send me an email and I'll respond with my number. I'll walk you through it.
9 years 9 months ago #87037 by cncnoob1979
FEATURES=30
That is what was wrong. It was missing from the ini file.
It's working now. Glad to hear it's fixed.
Time to create page: 0.070 seconds
