Threading on Sherline lathe
9 years 2 months ago #96982 by techrat
Replied by techrat on topic Threading on Sherline lathe
Just jumping on this thread (Pun intended) quickly as I have been battling with getting G76 to work predictably on my lathe. I am wondering if you had more difficulty with G76 or G33? Did you start using G33 and saw better results? My current challenge may be related to the Q factor on G76 as it appears as though my tool is advancing too far with each subsequent pass and I end up with a wide flat at the root of the tread and a sharp point on the top of the thread.
I will probably work with G33 to simplify and see if this helps but am also interested in your experiences with switching between the 2 G Codes.
Thanks,
Jeff
9 years 2 months ago #97099 by andypugh
Why not try a smaller value for Q if you think that is the problem? On manual lathes I have typically used a value of 0 and it works fine. (ie, apply cut with the cross-slide not the compound)
What type of thread are you cutting? Commonly used thread angles vary between 47.5 (BA) and 80 degrees (Panzergewinde) and you would typically set Q to fractionally less than half the thread angle.
I have never checked, but it is possible that the angle changes depending on whether one is in radius mode or diameter mode (it shouldn't, but....)
9 years 2 months ago #97101 by techrat
Thanks for the reply! Over the weekend I decided to go through everything from the ground up and double checked my set-up. In the end, it boiled down to some really basic errors in the physical set-up of my machine rather than the program or control. After re-grinding the tool myself and setting it properly, my test thread came out perfectly first try.
Just a good reminder for me to start at the beginning when troubleshooting.
Thanks Again,
Jeff
