Changing acceleration values during runtime
  • Shu
  • Shu's Avatar Topic Author
  • Senior Member
  • Senior Member
25 May 2017 10:26 #93606 by Shu
Is it possible to change the acceleration values of single axis during runtime? I would like to have GUI elements for all axes where I can temporarily limit the acceleration values. I found I can read out the the [TRAJ] DEFAULT_ACCELERATION, but no function to write an acceleration value.
Cheers,
Shu
25 May 2017 12:28 - 25 May 2017 12:30 #93614 by Todd Zuercher
Replied by Todd Zuercher on topic Changing acceleration values during runtime
Sort of. I know you can change it while Linuxcnc is open. But I'm not sure it works (at least not in real time) while running a G-code file (in auto mode).
The pins ini.N.max_acceleration can be used to change the acceleration for each joint.
Last edit: 25 May 2017 12:30 by Todd Zuercher.
19 Feb 2019 11:56 - 19 Feb 2019 11:59 #126764 by thang
Does these pins have any effect?
ini.traj_default_acceleration - (float, in) [TRAJ]DEFAULT_ACCELERATION
ini.traj_default_velocity - (float, in) [TRAJ]DEFAULT_VELOCITY
ini.traj_max_acceleration - (float, in) [TRAJ]MAX_ACCELERATION
Default/max_acceleration always show 1e+99, Default/max_velocity show correct but change all of them dont have any effect when i jog or run auto program.
I'm using lcnc 2.8
Last edit: 19 Feb 2019 11:59 by thang.
22 Feb 2019 14:07 #126911 by pl7i92
Replied by pl7i92 on topic Changing acceleration values during runtime
limiting the Speed Max value also takes effect on the ACC values
so you might consider to limit that in first hand
this is by halui
Time to create page: 0.853 seconds
