MESA 5I25 7I77 CAN DRIVE THIS MOTORS??
9 years 4 months ago #94040 by Yannis
if i got i right the difference is in the ini and the hal file of the axis
is it different the mesa configuration in the pncconf wizard ?
do you have the option in the wizard to define the machine with more then 4 axis?
can you post the files of the ini and the hal of your gantry for reference?
thanks for your patience
9 years 4 months ago #94043 by Todd Zuercher
I do not have any dual motor gantry machines. I am not sure how many axis Pncconf can set up, and I don't think it does dual motor gantries. And I am not even currently running Master on any machinery.
The following user(s) said Thank You: Yannis
9 years 4 months ago #94133 by Yannis
Hi
this is the pid settings in x axis
when i jog until 1300mm/min all seems in order
when i increase the speed to 1500 i have an axis error
any suggestions?
thanks
9 years 4 months ago #94134 by Yannis
9 years 4 months ago - 9 years 4 months ago #94137 by PCW
Yes, I would first set the following error and min following error to a few mm
and then plot the velocity and following error during a jog using HALScope,
its not really possible to guess what's wrong with just those PID parameters.
Last edit: 9 years 4 months ago by PCW.
9 years 4 months ago #94143 by Yannis
Can you point me what values i sud change increase or dicrease?
thanks
Time to create page: 0.062 seconds
