5 Days in LinuxCNC Install Hell
- kurta
04 Jun 2017 03:10 #94044
by kurta
5 Days in LinuxCNC Install Hell was created by kurta
I've installed 2.5 without problem.
I've installed the Wheezy package on my MacBook under VirtualBox. No problem. It all works great.
The goal was to update (complete reinstall) on the USB stick I use to run my production machine.
I've tried for 5 days to install the same package off the same DVD on:
1) USB
2) Dell Inspiron HD
3) HP Envy dv6 HD
No luck. (I know laptops aren't recommended, but thought I'd try. In any case I want to put the OS on a USB stick, and it should be okay to use a laptop to write the stick.)
I can get Wheezy to install ( on the laptop HDs, not on USB), but when I launch LinuxCNC I get a an error dump and the message that "LinuxCNC terminated with an error. When reporting problems, please include all the information below in your message."
How?
I can "select all" using the button at the bottom, but I can't copy.
Who knows? This may be an EASY problem for someone here to solve - but the problem I have now is how to get the diagnostics off the screen and into forum entry!
Meanwhile, I've run dmesg > errorfile, but don't know if it contains the right information.
1) USB
2) Dell Inspiron HD
3) HP Envy dv6 HD
How?
- Thank you received: 7490
04 Jun 2017 10:59 #94047
Replied by tommylight on topic 5 Days in LinuxCNC Install Hell
Parport 0 not found !
You are trying to start a config that uses parallel port, but there is none.
Choose one of the SIM configs and give it a try.
The following user(s) said Thank You: Tchefter
- kurta
04 Jun 2017 18:41 #94053
by kurta
Replied by kurta on topic 5 Days in LinuxCNC Install Hell
Wow! That was easy. Wish I'd used BEFORE I tore out the last of my hair!
Thank you!
Thank you!
04 Jun 2017 21:26 #94060
I can lend you some, i have plenty of it (hair) left, somehow! During winter i look like jeti !
- Thank you received: 4151
05 Jun 2017 12:02 #94083
Replied by rodw on topic 5 Days in LinuxCNC Install Hell
I think you've actually done pretty well to only have had 5 days in hell. Some of spent a lot longer idown there!
Time to create page: 0.114 seconds
