How to Use Servo Spindle as 'C' axis
9 years 4 months ago #94932 by PCW
The stepgen mode is a low level hal setting. It need not ever change from velocity mode
what changes is the signal that drives the velocity command.
In spindle mode (direct velocity mode) the wiring is like this
motion.spindle-speed-out -->xxxx.0.stepgen.03.velocity-cmd
In position (axis) mode the (simplified) wiring is like this:
joint.3.motor-pos-cmd --> pid.3.command
xxxx.03.stepgen.yy.position-fb --> joint.3.motor-pos-fb
pid.3.output-->xxxx.0.stepgen.03.velocity-cmd
This re-wiring can be done in a component or using one of the the existing mux components
The following user(s) said Thank You: Simpson36
9 years 4 months ago #94946 by andypugh
Simpson36 wrote: The orient component certainly has possibilities, but as is stands, if I understand it correctly from reading the man page, it is limited to a sweep of a single revolution, so it would need to be modified so that an infinite number of steps and/or degrees could be specified.
A potential problem is, again if I understand it correctly, that Orient does not seem to have an axis associated with it. I.e . there seems no mechanism by which g-code could command indexing. ex.(G1 C250 Fxx).
I think that both these issues can be addressed by connecting the C axis (typically joint.5.motor-position-cmd) to the orient.N.angle pin.
9 years 4 months ago #94947 by andypugh
PCW wrote: I don't think there's any issue with the stepgen position rolling over, since this is a 64 bit floating point number
It's actually a 64-bit integer step accumulator multiplied by a 32-bit scale. But it won't ever wrap in the expected life of the universe.
On the scale of tens of billions of spindle revolutions you eventually end up with sub-degree resolution.
9 years 4 months ago #94951 by PCW
Yeah, I was thinking of the loss of precision of the hal position (64 bit float)
a 32 bit float hal pin would go bad pretty quickly with large turn counts
9 years 4 months ago #94966 by andypugh
Actually, I think the scale is double (64 bits).
But, the fact that total steps is kept as a 64-bit integer means that any spindle would wear out before wrapping the counts.
9 years 4 months ago #94998 by Simpson36
Thanks again for the info and especially the examples. That makes it SO much easier by providing a starting point.
I have used the mux component so I am familiar with it . . somewhat.
Assuming the inputs would be muxed using logical OR into xxxx.0.stepgen.03.velocity-cmd
Then I have one more question before digging into this. In my use of mux, I do not recal there being an explicit forced switch . . i.e. IN#1/IN#2 (or equiv).
Question: is there an explicit trigger for mux, if so I must have missed the instructions. Can someone point to them?
If there is NOT a switch for the mux, then is it safe to assume that the 'Spindle' and the 'C' would not be active at the same time and therefor safe to mux without explicit control of the mux?
What is driving that question is concern over potentially unwanted buffered data in the two inputs to the mux.
I will have other questions for sure, but this will get me going.
Thanks!
Time to create page: 0.151 seconds
