Spindle encoder wiring check
8 years 11 months ago #101591 by timmert
Not sure if I understand it correctly. But would I need an encoder to my z axis?
8 years 11 months ago #101593 by andypugh
I am saying that you can add extra hardware to supply an index pulse entirely separately from the existing encoder.
8 years 11 months ago #101594 by timmert
I have an index and 360ppr.
What do you recommend to use rigid tapping?
Sorry my knowledge about electronics is limited.
8 years 11 months ago #101607 by andypugh
Can you re-state the current question? I have rather lost the thread here, even after reading back from the beginning.
8 years 11 months ago #102253 by timmert
I'm using the starter encoder that was installed on my lathe
This is a encoder with an index and 150ppr.
This should be enough for threading.
But I want to do rigid tapping.
So I will need a quadrature encoder.
The current encoder is connected with a toothed belt to the spindle.
8 years 10 months ago #102789 by timmert
This should work I guess?
A and B channel
And Z for Index
5-24V
www.aliexpress.com/item/Incremental-Rota...b04&rmStoreLevelAB=0
Time to create page: 0.203 seconds
