Spindle encoder wiring check
8 years 10 months ago #102796 by PCW
Replied by PCW on topic Spindle encoder wiring check
That's an open collector interface encoder
It should be OK but if you have differential inputs, a E6B2-CWZ1X would be better
Also 2000 PPR is too high resolution for parallel port reading at more than a few hundred RPM
8 years 10 months ago #102797 by timmert
What's a good PPR?
This one is 1024PPR. The E6B2-CWZ1X isn't open?
www.aliexpress.com/item/1pcs-E6B2-CWZ1X-...f76&rmStoreLevelAB=0
8 years 10 months ago #102826 by PCW
The maximum resolution (PPR) you can use depends on your hardware
What hardware are you using?
8 years 10 months ago #102830 by timmert
I use a 7i76/5i25
8 years 10 months ago #102835 by PCW
OK so you can pretty much use any resolution encoder
Encoders with differential (line driver) outputs like the E6B2-CWZ1X
will have better noise immunity than TTL or open collector types
The following user(s) said Thank You: timmert
8 years 10 months ago #102837 by timmert
Thanks for the information PCW
I ordered the 2500PPR E6B2-CWZ1X
Time to create page: 0.186 seconds
