Linuxcnc - s-curve acceleration? (7176e)
8 years 3 months ago #114899 by Grotius
Robert Ellenberg is not so active anymore last years. His github channel is stil alive. I merged his code, so i know what he is capable too. Robert is an expert.
For linuxcnc the main folder structure picture is missing. So new academic users, don't know where too find someting.
I prefer to make some thing like the attachment too make things easer to find instead of wasting time on porn.
image missing https://linuxhere.files.wordpress.com/2010/08/lintimeline1.png
The following user(s) said Thank You: tommylight, FDP
8 years 2 months ago - 8 years 2 months ago #115611 by FDP
I am going to try to sit down over the next month and try my hand at documenting some of the source. I'm doing an LCNC router conversion so I will have some extra motivation.
I'll start off with some kind of an organized approach on Github (unless there is a better, non-MSFT option) and once I have something there I'll check back in on this thread with an update.
Are there any individuals on the forum, or threads I should look to to try to get deeper insight into the codebase?
Last edit: 8 years 2 months ago by FDP.
8 years 2 months ago #115654 by grijalvap
Is anybody we can pay for, if yes maybe we can start a donation campaign or even a Kickstarter campaign to get money to pay for this development.
what do you think?
8 years 2 months ago #116189 by grijalvap
No comments?
7 years 6 months ago #130949 by warreng
Sorry, my post is not any kind of update. But instead a question. I'm curious about how many of the "advantages" of limited jerk acceleration processing can be compensated with G-code. I'm sure my naivety is showing...
When I first started using Fusion360 to write toolpaths for an older commercial CNC router (instead of ArtCam) I immediately noticed a different personality to the motion. I would think that if your G-code is coarse then your only hope for smooth motion and optimized acceleration is for your controller to manipulate the situation. But if the G-code is more data dense then I can imagine that the bigger acceleration booboos can be handled right at the start. Any comments that might help me understand this more completely?
7 years 6 months ago #130985 by PCW
CAM and the actual chosen shape of machined surfaces can have a direct effect on the acceleration and jerk profiles.
If you consider constant surface speed machining, the actual curve you are machining
entirely determines the acceleration and jerk , as long as you don't exceed machine
constraints, the CNC's trajectory planners jerk/acceleration limits have no real effect.
Time to create page: 0.573 seconds
