Activating air blow valve M6
- lesureia
24 Oct 2017 07:24 #100730
by lesureia
Replied by lesureia on topic Activating air blow valve M6
By precise i was thinking more controllable.
If i were to go with this solution i dont know where to begin other than the page that you linked to earlier.
But i will read up on this and give it a try.
/Rickard
/Rickard
- Thank you received: 4648
24 Oct 2017 08:00 #100731
Replied by andypugh on topic Activating air blow valve M6
Can we go back to the beginning? I was assuming that if you needed an air blow valve that you had an automatic toolchanger and a remapped G-code routine to handle that. Looking back I am wondering if I have confused this thread with another one.
Are you simply using hal_manualtoolchange? Is the air blast to clean the spindle or to release the tool?
- lesureia
24 Oct 2017 08:18 #100734
by lesureia
Yes i am using hal manualtoolchange with a switch to measure tool length.
Its manual mounting of tool in the spindle
The air blast is to clear chip off before measuring tool.
i was searching the forum for an answer but could not find one so i asked.
And its working Thanks to you.
24 Oct 2017 09:01 #100737
So, if you are doing automatic tool-length measuremment then I assume you already have a G-code remap for the M6 command? So you could add a line to that G-code to trigger the air blast at the perfect time.
- lesureia
24 Oct 2017 09:31 #100738
by lesureia
its this example i have on my machine sim/axis/remap/manual-toolchange-with-tool-length-switch
And yes there is a remap line in my INI file
remapping toolchange - related codes
# see python/remap.py for the prolog and epilog handlers
# see nc_files/remap-subroutines for the NGC procedures
# the prepare_min.ngc and change_min.ngc are templates - fill in as needed
REMAP= M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
24 Oct 2017 10:40 #100741
OK, so you could consider adding an M64 to the manual_change.ngc file at the point where you want to start the air blast, then an M65 at the point in the sequence when you want it to stop.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m62-m65
Assuming M54 P0 is used then you would connect motion.digital-out-00 to the solenoid pin. Or, if you want a specific timed length of blast, to the oneshot input pin.
- lesureia
24 Oct 2017 10:51 #100742
by lesureia
I will give this a try this weekend.
Have little time this week to test this.
Thank you again.
/Rickard
Thank you again.
/Rickard
- lesureia
28 Oct 2017 07:57 #100915
by lesureia
I think its done now.
i put this line in my HAL linked to oneshot so i can control the width of blow time.
net digital-out-0 motion.digital-out-03 => airblow1.in => hm2_5i25.0.7i76.0.0.output-01
Then wrote M64 P03 in manual_change.ngc right after probing and a few lines down M65 P03.
Increased my digital outputs also since i was running out of them.
Thank you again.
/Rickard
Thank you again.
/Rickard
Time to create page: 0.190 seconds
