LinuxCNC S-Curve Accelerations
5 years 4 months ago #212806 by TheRoslyak
Replied by TheRoslyak on topic LinuxCNC S-Curve Accelerations
What's wrong? Perhaps I forgot to do something?
5 years 4 months ago - 5 years 4 months ago #212818 by arvidb
Replied by arvidb on topic LinuxCNC S-Curve Accelerations
It looks like it's trying to load a different motmod.so than the one built from the smooth1d branch. I would recommend that you don't install the smooth1d code just yet, but use "Run In Place" instead.
Something like this should do it for the build:
$ git clone https://github.com/arvidbrodin/linuxcnc.git linuxcnc-smooth1d $ cd linuxcnc-smooth1d/src/ linuxcnc-smooth1d/src$ git checkout smooth1d linuxcnc-smooth1d/src$ ./autogen.sh linuxcnc-smooth1d/src$ ./configure --with-realtime=uspace linuxcnc-smooth1d/src$ make -j4 linuxcnc-smooth1d/src$ sudo make setuid
Then to run it:
cd </path/to/>linuxcnc-smooth1d linuxcnc-smooth1d$ . scripts/rip-environment linuxcnc-smooth1d$ linuxcnc
To run your normal install again, just reboot the machine to reset the "rip-environment". You can see which linuxcnc build is "active" by typing
$ which linuxcnc
Last edit: 5 years 4 months ago by arvidb.
5 years 4 months ago - 5 years 4 months ago #212821 by TheRoslyak
Not. Something wrong. Same error.
The regular version starts - So globally nothing has screwed up
Previous version works. But I still haven't figured out how to check
Last edit: 5 years 4 months ago by TheRoslyak.
5 years 4 months ago #212827 by TheRoslyak
Return to the question of how to set it up.
I compared the regular version and the smooth version. The differences seem to be there, but not significant. Perhaps it was necessary to accurately scale the scope. But there seem to be differences - judging by the scope.
In this version, can I somehow customize the S-Curve Accelerations parameters?
5 years 4 months ago - 5 years 4 months ago #212831 by arvidb
I have managed to reproduce the "linuxcnc-smooth1d/rtlib/motmod.so: undefined symbol: smooth1d_reset_pos" error. Something is still wrong in the build scripts. I'm looking into it now.
Edit: It seems to be an ordering issue between the different object files during linking. Still working on it...
5 years 4 months ago #212835 by arvidb
I have pushed another commit to my repo which should fix the "linuxcnc-smooth1d/rtlib/motmod.so: undefined symbol: smooth1d_reset_pos" build error. It would be GREAT if someone with more knowledge on the LinuxCNC build system (and/or makefiles in general) could take a look at my changes and see if the linking of the smooth1d library can be done in a better way. Now I have written a specific rule for motmot.so which isn't a very nice solution. Also the library is listed both as a dependency for motmod.so (part of $^) and as a linker include command (-lsmooth1d).
TheRoslyak: Please try the new version. No, there is no way to configure the jerk limit at the moment; it is auto-calculated based on your max acceleration and max velocity settings for each joint. It should "just work". But a manual config option could be added later if necessary. In your halscope images I cannot see any trace of jerk limiting (the velocity plots are straight lines) so I'm guessing you weren't running the smooth1d version (because of the build issue?).
If you still cannot see a difference after a successful build, please post your joint acceleration and velocity settings.
Time to create page: 1.633 seconds
