g54 issue
26 Oct 2017 16:04 #100840 by jlroch
Replied by jlroch on topic g54 issue
i clear it, but it keeps coming back, sometimes in the home z line as well as the g54 z line, other times in the home z line as well as the tl0 z line.
and i also now have a situation where as soon as i ok the insert tool command and step to the next line, it plunges the end mill right up to the chuck jaws.
jacques
p.s. i think the deities are bored and amusing themselves with me..... :-)
26 Oct 2017 16:06 #100841 by jlroch
jacques
26 Oct 2017 17:20 #100843 by Todd Zuercher
Replied by Todd Zuercher on topic g54 issue
They do seem like to do that sort of thing.
It is kind of hard to guess what you have going wrong without seeing everything and how they interact. (machine config, g-code file, and even the actual physical machine.)
26 Oct 2017 18:52 #100846 by jlroch
yeah, i know. is there a way of "resetting " everything to default (short of uninstall/install linux cnc)?
26 Oct 2017 19:41 #100847 by jlroch
ok. finally i get to thumb my nose at the deities!!!!
turns out that there is some kind of setting in my cam software (artcam) that is inserting that value "automagically" (probably as the result of my lack of comprehension of the cam software). i have put in a tech support call to autodesk so that they can help me with the problem. i will keep you posted.
thanks for your everlasting patience and sense of humor....
26 Oct 2017 22:27 #100860 by andypugh
Replied by andypugh on topic g54 issue
Many CAM softwares insert a "G53 Z0" at the start of each program.
Now, on most machines Z = 0 is the top of travel and if there is 200mm or travel then the bottom of Z travel is -200.
I suspect you have set your machine up as 200 > 0 rather than 0 > -200 ?
Change the Z axis limits in the INI file and you will probably be OK.
27 Oct 2017 03:16 #100870 by Todd Zuercher
That and stop using the home button as a touch off. Keep the machine Z0 at the top of travel where it belongs.
27 Oct 2017 14:56 #100884 by jlroch
ok. so here's the result after autodesk support intervention.
turns out that in the post file for the "linux cnc inch" created by autodesk, there is a g43 line with an h value that conflicts with the manual value (when the z is set via home) of the z axis. the technician remarked that line out and all is well.
here is the post file with the rem line if anyone is interested:
; LinuxCNC PostP file for TC and ARC support
; JT 12/27/13 Created
DESCRIPTION = "LinuxCNC_Arc_inch_TC_No_H(*.NGC)"
FILE_EXTENSION = "ngc"
UNITS = INCH
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.4]
FORMAT = [Y|#|Y|1.4]
FORMAT = [Z|#|Z|1.4]
; Arc Center Coords
FORMAT = [I|@|I|1.4]
FORMAT = [J|@|J|1.4]
; Home tool positions
FORMAT = [XH|@|X|1.4]
FORMAT = [YH|@|Y|1.4]
FORMAT = [ZH|@|Z|1.4]
; Tool Number
FORMAT = [T|@||1.0]
; Set up program header
START = "([FILENAME])"
START = "(Material Size) (X=[XSIZE], Y=[YSIZE], Z=[ZMATERIAL])"
START = "G90G80G20G49"
START = "G64 P0.001"
START = "M6 T[T]"
START = "(Tool Number:[T]) ([TOOLDESC])"
;START = "G43 H[T] G0[ZH]"
START = "M3 "
; Program moves
FIRST_RAPID_RATE_MOVE = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE = "[X] [Y] [Z]"
FIRST_CW_ARC_MOVE = "G2 [X] [Y] [J] [F]"
CW_ARC_MOVE = "G2 [X] [Y] [J]"
FIRST_CCW_ARC_MOVE = "G3 [X] [Y] [J] [F]"
CCW_ARC_MOVE = "G3 [X] [Y] [J]"
NEW_SEGMENT_POST_TOOLCHANGE="(Tool Number:[T]) ([TOOLDESC])"
NEW_SEGMENT_POST_TOOLCHANGE= "M3 "
;Setup Toolchange Commands
TOOLCHANGE = "G0[ZH]"
TOOLCHANGE = "M5"
TOOLCHANGE = "G49"
TOOLCHANGE = "M6 T[T]"
TOOLCHANGE = "G43 H[T] G0[ZH]"
; End of file
END = "G0[ZH]"
END = "G0[XH][YH]"
END = "M5"
END = "M30"
; M30 = program end and rewind
thanks for all the help from everyone in this time of difficulty. i will pay it forward whenever i can...
jacques
The following user(s) said Thank You: DJB
29 Nov 2017 20:38 #102506 by DJB
Replied by DJB on topic g54 issue
I appreciate the info on the G43 and Fusion 360, I was having the same issue with starting a file homing, touching off and then getting a plunge into the material 0.511 I saw where the tool offset was set.....but was going down the wrong path to compensate for it.
Now that I know to either comment out the G43 or add a G49 (Tool length cancel) I can move on to my next learning exercise.
Thanks DJB
29 Nov 2017 20:52 #102507 by andypugh
Rather than comment-out the G43 it would be better to ensure that the tool length in the tool table is correct for each tool (or, if not, then that every tool in the table has the same length)
Time to create page: 0.145 seconds
