unexpected realtime delay on task 0
- thang
- Thank you received: 11
01 Nov 2017 04:04 #101097
by thang
Replied by thang on topic unexpected realtime delay on task 0
here is my system info for core i3 and core i5 pc (today i cant turn on dual core pc
- Ozzyrob
- Visitor
01 Nov 2017 04:59 #101098
by Ozzyrob
Replied by Ozzyrob on topic unexpected realtime delay on task 0
I'm guessing it will have something to do with System management mode, as the dereference in the i3 & i5.
Operations in SMM take CPU time away from the applications, operating system kernel and hypervisor, with the effects magnified for multicore processors since each SMI causes all cores to switch modes. To quote from en.wikipedia.org/wiki/System_Management_Mode.
It may be a case of these machine being unsutiable...maybe this is an uneducated guess.
I did a bit of a search and found this thread on stackoverflow
stackoverflow.com/questions/25399405/eva...x-centos-intel-machi
Link to the manpage of hwlatdetect
manpages.ubuntu.com/manpages/xenial/man8/hwlatdetect.8.html
This will not fix the problem but should give an indication of what is happening. (hopefully)
- thang
02 Nov 2017 02:29 #101172
by thang
Thank for your help very much.
I finally fixed this problem. It's my mistake when i didnt see in wiki.linuxcnc.org/cgi-bin/wiki.pl?FixingSMIIssues, there is a solution about using smictl to fix this at the end of page(section 10) which i didnt notice.
Now, i already installed linuxcnc(RIP build) use preempt-rt kernel on ubuntu 16.04. After disable multicore/cpus,i can get 7us latency with x3 glxgears,surf web and coppy a large file.
- Ozzyrob
- Visitor
02 Nov 2017 02:32 #101173
by Ozzyrob
Sweet be sure to make a wiki entry
- thang
02 Nov 2017 02:42 #101174
by thang
i will make a guide about installing linuxcnc with preempt kernel on ubuntu 16.04 soon
- Killer
07 Dec 2021 08:57 #228511
by Killer
Replied by Killer on topic unexpected realtime delay on task 0
Hi Thang, I'm suffering the same thing, did you happen to do an idiot's guide to resolving this error
If so I'm all ears
I'm not sure how to use "smictl", if you can help that would be awesome! cheers Rich
Time to create page: 0.302 seconds
