5i25_7i77_bob.bit required
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
28 Oct 2017 05:21 #100911 by Diederik
5i25_7i77_bob.bit required was created by Diederik
Hi Everyone,
I am trying to use a 6i25 - 7i77 - Cheap Breakout board.
I did this before with a 7i76e, and used 7i76e_bstech.bit... or something similar. I'm using a 6i25, and from the 6i25 I want to connect to a 7i77(and up to here, all is okay), and a Breakout board, to control a spindle position/index control/C-Axis which requires 5v Step/Dir.
I loaded the following firmware: 5i25_7i77_bstech.bit.
This gives me the following pins availailable:
hm2_5i25.0.stepgen.00.control-type
-velocity-fb
-velocity-cmd
-position-fb
-position-cmd
-enable
-dbg_vel_error
-dbg_step_rate
-dbg_s_to_match
-dbg_pos_minus_prev_
-dbg_ff_vel
-dbg_err_at_match
-counts.
I don't see the following:
-position-scale
-steplen
-stepspace
-dirhold
-dirsetup
Please advice if I should use different firmware, and what firmware I should use for this setup.
28 Oct 2017 14:27 #100927 by PCW
Replied by PCW on topic 5i25_7i77_bob.bit required
Those are parameters, not pins, and will be present for any configuration that has step generators
  • Diederik
  • Premium Member
  • Premium Member
30 Oct 2017 04:21 - 30 Oct 2017 04:28 #101000 by Diederik
Replied by Diederik on topic 5i25_7i77_bob.bit required
Hi Peter.
Thanks for your reply.
Okay, My Bad... You're right... I'm going to try this again. Will let you know on the progress. Not sure what I did wrong on friday(actually, the problem was that it was friday, ... :D), but Linuxcnc is starting up now, and ... I need to test it, and will give feedback soon.
Last edit: 30 Oct 2017 04:28 by Diederik.
