- Thank you received: 88
The PID updates once per mS. Modbus can transfer hundreds of registers in that time.0x2102 wrote: The ModBus reading would be too slow to drive the PID.
With modifications, probably. You would need to add together all three numbers (incremental encoder counter float position, mutli-turn and single turn)Does your example this still apply?
