Modbus input for absolute encoder position?
1 year 8 months ago #320613 by Todd Zuercher
First thing you'd need to do is convert your signed integer encoder counts and turn counts to floats using the CONV_S32_FLOAT hal component. Then you would need to multiply the turns by 65536 and that and the counts together to get the total counts, finally you would need to multiply the total counts by your encoder scale to get the distance (or if a rotary axis degrees.) You could do most of the summing and scaling in a single step using the SUM2 hal component since each of the SUM2 inputs have their own scale factor inpout.
But I'm not exactly sure how you might use that position information to set the home position for homing the axis in Linuxcnc. (But I think it could/can be done.) Also remember that data feedback from modbus isn't in real-time, and is subject to significant transmitting delays and resulting inaccuracy, So you will need to only use that feedback for position when stopped or only for "rough" positioning when moving.
The following user(s) said Thank You: Ehsan_R
1 year 8 months ago #320619 by Martin.L
My servos just need a boolean input, guess yours need the same
1 year 8 months ago #320733 by Ehsan_R
Yes, it is as you say, but I only want to use it for homing. That is, instead of using the limit switch at the start of the movement, when the homing command is sent, it opens the RS485 port, reads the encoder value, and if it receives the result, it considers it as the home position, and then closes the RS485 port.
1 year 8 months ago #320734 by Ehsan_R
I use this servo motor.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
9 months 2 weeks ago #341463 by harindugamlath
Hi, did anyone get this to work?
I'm planning to use delta absolute servos for a retrofit, I'm very familiar with mesa hardware and really like to use absolute servo position for homing.
Time to create page: 0.261 seconds
