7i77 firmware
- Diederik
01 Nov 2017 22:04 #101160
by Diederik
7i77 firmware was created by Diederik
I recently updated a old pc, to wheezy, and 2.7.11, but I'm now getting a error saying the 7i77 firmware is old/outdated. I solved a problem like this before, But I can't remember and also can't find the command to update the 7i77 firmware.
I know I must set W4 & W12 to setup mode, but then, what firmware is correct? And what command do I use?
- Thank you received: 5321
01 Nov 2017 22:34 #101164
Replied by PCW on topic 7i77 firmware
freeby.mesanet.com/software/parallel/sserial.tgz
has the new firmware and the scripts plus a readme file of instructions
The following user(s) said Thank You: Diederik
- Diederik
02 Nov 2017 04:23 #101177
by Diederik
Replied by Diederik on topic 7i77 firmware
Thank You very much Peter.
