Went to start up mill and none of the axis will move?
05 Nov 2017 23:27 #101381 by jamby
JT
Out on Hood Canal in Washington State. Just north of Lilliwaup, down the road from Duckabush.
Jim
05 Nov 2017 23:32 #101382 by BigJohnT
Close to XXCoder then quite a bit from me in Swamp East Missouri....
JT
06 Nov 2017 16:43 #101438 by PCW
If you continue to get the sserial errors on startup, it may be a hardware failure of
some kind (maybe electrical damage when changing cables?) so I would request an
RMA and send the complete card/cable pair back to Mesa for evaluation/repair/replacement
06 Nov 2017 19:52 #101460 by jamby
PCW
The computer starts up and when linuxcnc is started no errors are shown. With power on the 7i77 and the mill servos powered up everything looks like it should until jogging any axis. That's when the following error occurs. The serial port errors appeared later when I was operating the machine in manual mode.
Don't know if that makes any difference.
Jim
06 Nov 2017 20:17 #101462 by andypugh
About the only thing I remember doing was disconnecting the serial cable from the computer to see if I had enough length to move the box to another location.
Which serial cable?
06 Nov 2017 21:13 #101465 by jamby
Andy
Its a parallel port cable that came with the card set 5i25-7i77
Jim
06 Nov 2017 21:16 - 06 Nov 2017 21:18 #101466 by jamby
PCW
Sorry I am giving you bad information. The serial port errors appear because the power to the 7i77 (which is in a separate box) is turned off. Otherwise the only error messages are joint x following errors.
Sorry for muddying the waters.
Jim
Last edit: 06 Nov 2017 21:18 by jamby.
07 Nov 2017 00:44 - 07 Nov 2017 00:44 #101480 by PCW
OK so it looks like at least the 5I25 --> 7I77 stuff is working
I would check the analog outputs and the drive enables
You may want to set the following error limits wider for testing, maybe 1/2 an inch or so.
This is because the first thing that happens with a following error is that the drive enables are
turned off and the analog outputs are disabled
Last edit: 07 Nov 2017 00:44 by PCW.
The following user(s) said Thank You: jamby
07 Nov 2017 17:37 #101497 by jamby
PCW
Found it! It was a loose connection at the P7 connector on the PCB803 card. Once I reseated that everything worked as before. I am sure this is because of something I was doing while looking into getting rid of the old anilam control completely.
Thanks for leading me back to the light..
Jim
07 Nov 2017 19:07 #101505 by PCW
Great, glad it was something simple
Time to create page: 0.374 seconds
