NVUM/NVEM Ethernet controller
- dasbrow
06 Nov 2017 15:57 #101429
by dasbrow
NVUM/NVEM Ethernet controller was created by dasbrow
I am pretty new to Linuxcnc and bought one of the EVUM 6 axis Ethernet controllers from ebay and now that I have done a little more research I am leaning to the possibility that this was a mistake. Has anyone tried to use one of these? Or do I have a new paper weight?
- Thank you received: 1480
06 Nov 2017 17:12 #101442
Replied by Todd Zuercher on topic NVUM/NVEM Ethernet controller
I would be very surprised if a motion controller product like that (designed for Mach3) could be made to operate as a breakout board/hardware step-generator for linuxcnc. If it is possible it would probably require a complete reprogramming of its firmware. There are far easier options.
08 Nov 2017 13:16 #101519
Replied by andypugh on topic NVUM/NVEM Ethernet controller
I think that you have three options:
1) Cheapest: Keep the driver and use Mach3. Mach3 has lots of happy users, it must work well enough for most.
2) Most expensive: Sell or discard the driver and buy something LinuxCNC-supported
3) Most difficult: Write a HAL driver for the NVEM board modelled on hm2_eth. This would require information about the communications protocol that I have not been able to find in any of the online manuals
- Abdulwhab
25 May 2018 10:40 #111108
by Abdulwhab
Replied by Abdulwhab on topic NVUM/NVEM Ethernet controller
I have the same issue, did you find a solution?
- mehdidadash
- Thank you received: 4
25 Jul 2022 09:08 #248229
by mehdidadash
Replied by mehdidadash on topic NVUM/NVEM Ethernet controller
no solution yet ?
- MX_Master
- Thank you received: 48
25 Jul 2022 10:00 #248231
by MX_Master
Replied by MX_Master on topic NVUM/NVEM Ethernet controller
Free solution by scotta - forum.linuxcnc.org/18-computer/44828-rem...ernet-nvem-cnc-board
And I have a paid solution.
- mehdidadash
25 Jul 2022 12:20 #248250
by mehdidadash
Thank you .
what is the paid solution?
- MX_Master
26 Jul 2022 12:21 #248318
by MX_Master
You need a closed loop system. I have a NVEM soft only for the open loop system.Thank you .
Time to create page: 0.537 seconds
